1993 Chevy Suburban Engages in 1 or 2 but not D
MJANDME
  • 1993 CHEVROLET SUBURBAN
  • V8
  • 4WD
  • 13,800 MILES
My Suburban was sitting for a couple years after the rear end blew apart. After getting the rear end rebuilt, I tried to start out in Drive but it wouldn't go. It starts out fine in 1 or 2 and then can be shifted into D no problem. Once I come to a stop I have to go in 1 or 2 to start oout again. The trans fluid was low (had a pan leak) and topped off but didn't make a difference.
Wednesday, January 7th, 2009 AT 11:49 AM
2CARPRO JACK
  • 11,533 POSTS
Sounds like something sticking in the valve body. Have you driven it long enough to get the trans hot? Sometimes that will unstick valves in the trans. If not, then a trip to a trans shop may be in order, it doesnt sound like it needs any work beyond some in the valve body
Thursday, January 8th, 2009 AT 12:20 PM
MJANDME
Jack- Thanks for the response.
I drove it home, about 18 miles/30 minutes so I think it would have gotten the trans hot.
"Check valve body" sounds better than "need rebuild, so I'm hopeful.
Thursday, January 8th, 2009 AT 1:52 PM
2CARPRO JACK
  • 11,533 POSTS
If you can manually shift through the gears and it will work, then it should just be in the valvebody
Thursday, January 8th, 2009 AT 2:08 PM
