1987 Chevy Silverado Hot No-Start
FIRE41
I have a 1987 Chevy 153000 miles 305 v8 has a 1979 motor recently timing gear and chain was replaced now you can drive it 3 or 4 miles shut it off will not start real slow to turn over when its cold it will spin over good ........thanks
Feb 12, 2007 at 4:05 AM
  • 75,988 POSTS
Test battery with load tester or the starter disable the ignition remove HEI connector should maintain 9.6volts in 10secs and double check the connections-to include a check on the ignition control module their known on HEI ignition
Feb 13, 2007 at 8:12 PM
Suggested Repair
Load-test the battery and starter with the ignition disabled and the HEI connector removed; voltage should stay at least 9.6 volts for 10 seconds. Recheck battery and starter connections and inspect the HEI ignition control module.
Conversation Summary
The owner of a 1987 Chevy Silverado with a 305 V8 (a 1979 engine) says that after the timing gear and chain were replaced, the truck cranks very slowly and will not restart after a 3- to 4-mile drive, although it cranks normally when cold. The expert recommends a battery load test or starter test with the ignition disabled and HEI connector removed, expecting at least 9.6 volts for 10 seconds, plus checking connections and the HEI ignition control module.
