FIRE41
I have a 1987 Chevy 153000 miles 305 v8 has a 1979 motor recently timing gear and chain was replaced now you can drive it 3 or 4 miles shut it off will not start real slow to turn over when its cold it will spin over good ........thanks
Feb 12, 2007 at 4:05 AM
  • 75,988 POSTS
Test battery with load tester or the starter disable the ignition remove HEI connector should maintain 9.6volts in 10secs and double check the connections-to include a check on the ignition control module their known on HEI ignition
Feb 13, 2007 at 8:12 PM
