2003 Chevy Silverado Speedometer Out
BULLLADY69
I have a 2003 chevy silverado approx 83000 miles on it and a 5.3 v8 engine. my speedometer quit working but all my other guages work and also my cruise control is still working. DO i need a sensor or the whole cluster?
Nov 5, 2007 at 11:31 AM
DENNYP
  • 1,824 POSTS
[quote:681b6bf991="bulllady69"]I have a 2003 chevy silverado approx 83000 miles on it and a 5.3 v8 engine. my speedometer quit working but all my other guages work and also my cruise control is still working. DO i need a sensor or the whole cluster?[/quote:681b6bf991]had you noticed any noise from the cluster before the speedo quit?like a grinding noise or a rattle?
Nov 5, 2007 at 12:09 PM
BULLLADY69
no i didn't make any noise or anything but it would jump as you would start to speed higher into the 60-70 moh range
Nov 7, 2007 at 11:55 AM
DENNYP
  • 1,824 POSTS
[quote:04eccbbc3f="bulllady69"]no i didn't make any noise or anything but it would jump as you would start to speed higher into the 60-70 moh range[/quote:04eccbbc3f]you have a bad cluster.
Nov 7, 2007 at 12:54 PM
Suggested Repair
Replace the instrument cluster. The speedometer jumped at higher speeds with no cluster noise, while the other gauges and cruise control still worked, which points to a bad cluster rather than a speed sensor.
Conversation Summary
The owner of a 2003 Chevrolet Silverado with a 5.3 V8 reported that the speedometer stopped working while the other gauges and cruise control still worked, and asked whether a sensor or the whole cluster was needed. There was no grinding or rattling, but the speedometer had jumped as speed rose into the 60-70 mph range. The expert concluded the instrument cluster is bad.
