2003 Chevrolet Silverado Speedometer Stuck
UCFSAE81
I have a 2003 ext. cab 4.8L 2 wheel drive Silverado, while driving the other day my speedometer kept increasing pass the speed I was going. It now rest at 55mph or sometimes at 120mph. Everything else works on the truck just fine besides my speedometer saying that I am driving around 130mph all the time. Some people have said the dealership will replace the entire gauge cluster for $500 while other mechanics are saying it will take a week to find the problem. Has anyone else experience this problem before and what can i do to fix it.
Aug 7, 2007 at 4:03 AM
CLY
  • 308 POSTS
More than likely the problem will be in the cluster and it is not servicable so it would need replaced.
Cly
Aug 7, 2007 at 8:04 AM
SPETRILLI
Give this a try. It worked for me when my 2004 silverado started doing the same thing on 8/28/07.
With the engine in park, turn the key and start the engine. Let it run for a few seconds and then turn it off. Each time you start the engine, you should see the speedometer do a slight reset by dropping the speed approx 5 mph. Mine was stuck at 60, but after turning the engine off and back on, it decreased by 5 mph each time until it reset to 0. Once it was back to 0, I then took it for a drive and the speedometer is still working correctly.
Aug 28, 2007 at 2:04 PM
Suggested Repair
The instrument cluster is the likely cause and is not serviceable, so replace the cluster. A similar Silverado was also reset by repeatedly starting the engine for a few seconds and shutting it off until the needle returned to zero.
Conversation Summary
A 2003 Chevrolet Silverado speedometer no longer rests at zero and reads far above actual speed, while the rest of the truck works. An expert said the cluster is likely faulty and must be replaced because it is not serviceable. Another owner reported that cycling the ignition several times dropped the reading about 5 mph each time until it reset to zero and then worked normally.
