Silverado Running Lamps
SLM
I have a burned out daytime running lamp on a 2002 Silverado and want to avoid the HUGE cost of having it replaced at a shop. I would like to know the procedure to change it myself. Thank you.
Jul 31, 2007 at 3:43 AM
CLY
  • 308 POSTS
If you open the hood and look at the headlight on the side that is out you will see to L shaped retainers. You turn those retainers to un-clip them and then they pull up and you can remove the headlamp assembly. Then you will see a retainer on the inboard side of the turnsignal/marker lamp. Push that retainer in and you should be able to take the lamp out. Change the bulb and reassemble...
Cly
Jul 31, 2007 at 8:44 AM
