STRUXGL
  • 11 POSTS
I have a 2000 Silverado with 86000 miles. It is a 4x4, 5.3 engine.
When I first start it in the morning it idles normal, about 500 but after driving a few it idles anywhere from 1000 to 1500. I can turn off the engine and it once again will idle fine until I drive it a few miles. Any suggestions?
Sep 16, 2007 at 4:04 PM
  • 75,988 POSTS
[quote:2bf255f0c8="struxgl"]I have a 2000 Silverado with 86000 miles. It is a 4x4, 5.3 engine.
When I first start it in the morning it idles normal, about 500 but after driving a few it idles anywhere from 1000 to 1500. I can turn off the engine and it once again will idle fine until I drive it a few miles. Any suggestions?[/quote:2bf255f0c8]
Try checking the throttle position sensor and clean out the idle air control valve, also the throttle body/plate and a binding throttle cable.
I almost forgot about the coolant temperature sensor-test its resistances hot and cold-could be stuck in the open loop mode and the computer is dumping fuel thinking the engine is still cold.
Sep 16, 2007 at 7:57 PM
