2002 Chevrolet Silverado Won't Start
RH_CHEVY
Silverado 1500 yr=2002, 4.3L, V6 vortec.
This is my wits end,.
here is what has transpired.....
recently replaced distributor, finally got timing right (via manual cranking of crankshaft etc while in nuetral and batt disconn.) now it fires correctly but wont start, does fuel pressure (regulator,ecm,etc.,) become "disabled" when battery is completely discharged or disconnected? as i have spark at coil and at plugs. does system need a "prime" i.e. a bit of gas in the T.B. opening to get fuel re-applied? I have not tried this yet, as I would like to hear any input from someone. this is a relatives' truck and am doing him a favor by replacing the distributor (original was almost destroyed, upper bearing in housing was gone), getting timing right was difficult but I did get it as the engine turns over normally, his battery was also near dead so i replaced that, hence the ?? about discharge/disconnect with respect to the fuel pressure situation. NO, I do not smell leaking gas anywhere so I do not suspect fuel pressure regulator. any help would be great.
Nov 4, 2007 at 5:22 PM
  • 75,988 POSTS
Shoot some carb cleaner in the throttle body and see if it'll start if so-check the fuel pressure-hook up on the schreader valve left rear of the IMTV you will see the tire looking valve that's where you connect your fuel pressure gauge.
It should read 55-62psi while engine is at idle and it should maintain 25psi within 1 min. when key is turned off.
Good Luck
Nov 4, 2007 at 7:17 PM
Suggested Repair
Spray carburetor cleaner into the throttle body to see if the engine starts. If it does, check fuel pressure at the Schrader valve on the left rear of the intake manifold. It should read 55-62 psi at idle and hold about 25 psi within one minute after the key is turned off.
Conversation Summary
The owner of a 2002 Chevrolet Silverado 1500 4.3L replaced the distributor and battery. The engine cranks and has spark but will not start, and the owner asked whether a dead or disconnected battery disables fuel pressure or whether the system needs priming. The expert advised spraying carburetor cleaner into the throttle body as a starting test, then measuring fuel pressure at the Schrader valve if it fires.
