1993 GMC Sierra Grabby Clutch
TRIUMPHNUT
93 sierra 120k, 4.3 liter with 5 spd. Clutch is REALLY grabby after replacing with new. Pedal feels good, just no modulation. Not sure if mechanic replaced flywheel or just shaved it. Why would the clutch be so grabby? It's extremely hard to shift and take off from a stop smoothly. Slave and master cyl seem to be ok, no leaks.
Feb 25, 2007 at 2:20 AM
CHEVY22
  • 1,375 POSTS
hi
if you did not have this problem before , i would have to say either a faulty disc , disc in backwards , faulty pressure plate , slave cylinder is bypassing it could be working but not properly , i owuld take it back to the guy who worked on it , dump the headache on him while you watch a game on the tube , this is not your problem let him pullit back apart and figure it out
thanks
jim
oh and leave some feedback if you were happy with your help , we all donate our time here helping others free of charge
Feb 25, 2007 at 4:41 AM
Suggested Repair
Return the truck to the installer and have the clutch pulled back apart. Recheck for a faulty or backward clutch disc, a faulty pressure plate, and a slave cylinder that is bypassing or not releasing properly.
Conversation Summary
A 1993 GMC Sierra with a 4.3L and five-speed developed a very grabby clutch after replacement, with little modulation and difficult smooth takeoffs. The pedal felt normal and the master and slave cylinders showed no leaks. The expert said the new problem could be a faulty or backward disc, a bad pressure plate, or a slave cylinder that is not working properly, and advised having the installer disassemble and correct it.
