2004 Chevy Silverado Passenger Hot Air Fix
RDRK
2004 chev silverado,80000 mi.,5.3l The dual climate control is blowing hot air from the passenger side no matter what the setting. The driver side setting has no effect. I did disconnect the battery previously for 30 min. Any correlation?
Sep 11, 2007 at 7:36 AM
DENNYP
  • 1,824 POSTS
[quote:bec26f8ca1="rdrk"]2004 chev silverado,80000 mi.,5.3l The dual climate control is blowing hot air from the passenger side no matter what the setting. The driver side setting has no effect. I did disconnect the battery previously for 30 min. Any correlation?[/quote:bec26f8ca1]you need to use the TECH2 scan tool to perform the HVAC actuator recalibration.If that doesnt work,you might have a bad actuator for the pass side temp door.
Sep 30, 2007 at 6:49 AM
Suggested Repair
Use a TECH2 scan tool to recalibrate the HVAC actuators. If that does not restore passenger-side temperature control, replace the passenger-side temperature door actuator.
Conversation Summary
A 2004 Chevrolet Silverado with dual climate control blows hot air from the passenger side no matter the setting, and the driver-side setting has no effect. Disconnecting the battery did not resolve it. The expert recommends HVAC actuator recalibration with a TECH2 scan tool and, if that fails, checking for a bad passenger-side temperature door actuator.
