2000 Chevrolet Silverado Blower Speeds
RLEWIS
I have a 2000 Silverado. The fan does not work on the first two speeds, but works fine for speeds 3 and above. What do I check? Is there a fuse for the first half?
Aug 23, 2007 at 12:26 AM
  • 55,808 POSTS
It sounds like you need front brake pads, the light comes on because the fluid is low in the master, when you install new front pads the fluid will refill itself and the light will go off. Please let me know
Jun 4, 2007 at 2:58 AM
  • 75,988 POSTS
[quote:859c8a37fc="rlewis"]I have a 2000 Silverado. The fan does not work on the first two speeds, but works fine for speeds 3 and above. What do I check? Is there a fuse for the first half?[/quote:859c8a37fc]
Could be the control switch but on your problem sounds more like the resistor
Aug 23, 2007 at 9:49 AM
Suggested Repair
Check the blower motor resistor first, since low fan speeds typically run through it while higher speeds can still work. The HVAC control switch is a secondary possibility.
Conversation Summary
The owner of a 2000 Chevrolet Silverado reports the air-conditioning fan does not work on the first two speeds but works on speed 3 and above, and asks whether a fuse controls the lower speeds. One reply discusses brake pads and low master-cylinder fluid, which does not address the fan issue. The relevant reply says the control switch is possible but the blower resistor is the more likely cause.
