1997 Chevrolet C1500 Differential Whine
TONY910
I have a 1997 Chevy C1500 P/u. For awhile now its been making a whine sound, sounds like from differential. Usually comes around 20 mph and stays on. Gets louder and louder as the faster i go. Only makes whine when accelerating or keeping constant speed. Ring and pinion bearing? or worn R&P?
Feb 12, 2007 at 3:08 AM
CHEVY22
  • 1,375 POSTS
sound like you may have the old ring and pinion whine , but tell you the truth i never do a gear set without replacing all of the bearings , its only about 100 bucks more and its the right way
jim
Feb 16, 2007 at 8:48 AM
Suggested Repair
Replace the ring and pinion gear set and all differential bearings together; bearings add little cost and should be renewed with the gears.
Conversation Summary
Owner of a 1997 Chevy C1500 reports a differential whine that starts around 20 mph, grows louder with speed, and occurs only while accelerating or holding speed. Expert says it sounds like classic ring-and-pinion whine and recommends replacing all bearings whenever the gear set is replaced.
