Brake lights and blinkers
BILLIS869
Im having a problem with my brake lights and blinkers for my tail lights. The brake lights will work when the headlights and parking lights are off but once you turn the headlights on the brake lights turn off. Once the brake lights are on and you turn the blinker on they blink really fast. All the light bulbs and fuses are good.
Nov 9, 2007 at 6:22 AM
MICHAEL FOX
Sounds like the same thing I just went through with my 94 Silverado. The blinkers woul dblink rapidly when the brakes were applied and the turn signal turned on. Brake lights wouldn't work when headlights were on. Turns out the problem was a bad ground in the tail lights. Check to see that there is enough play in the wires so that the ground doesn't become detached from the wire harness. That was my problem. Good luck!!
Feb 26, 2021 at 2:51 AM
MICHAEL FOX
BTW, it cost me $44 for a mechanic to find that same problem. Took him 15 miutes at most.
YENDY2
  • 11 POSTS
I had the same problem with my 1991 chevy truck. Drove me crazy for a long time trying to figure this out when I finally figured this out, I felt stupid that I didn't check it earlier. The ground wire on the back of the truck is supposed to be attached to the body, make sure it is attached good. This should fix your problem.
MAVIC
I'm Going Through The Same Issue Now, Glad There are Good People out here that share their own experiences with similar issues, Forums ROCK !!!!!!
  • 55,628 POSTS
Good to hear, please use 2CarPros anytime we are here to help.
Cheers, Ken
