service airbag system
2005 CHEVROLET SILVERADO
30,000 MILES • V8 • 4WD • AUTOMATIC
PCOLUCCI
  • 5 POSTS
my service airbag light came on (not accident related). I took it to a shop for diagnosis and they told me sensor location # 1 was where the fault code was. Can anyone tell me where location 1 is? I'm assuming it's the one mounted on the radiator core support but i want to be sure before I start tearing into it. Any help would be appreciated, thanks
Paul
Feb 23, 2009 at 2:33 AM
RACEFAN966
  • 5,029 POSTS
It is the left side impact sensor. Now I recomend that you get a book or get the proper procedure to disable the air bags before working on them or they may end up deployed and that will cost a lot more.
Here is the disable procedure. First point the wheels straight ahead and then remove the key from the ignition do not put them back in at all. Now remove the SIR fuse from the fuse box. Give it about a minute to before going on. Now unplug both sensors and replace the bad one. Now reconnect the connectors and then put the fuse back in. Now keeping clear of the air bags turn the key on engine of the air bag light should flash 7 times and then go out. Thats it your done. But with only 30000 isn't it still under warranty?
Feb 23, 2009 at 7:50 AM
PCOLUCCI
  • 5 POSTS
Thanks for replying so quickly. It's an 05 so with a 3/36 as far as I know it isn't under warranty any more even if it has only 29+ k miles on it. I thought I heard the mechanic talk about removing the front under pan cover/splash shield (whatever it's called, I'm not a truck guy) to access the sensor. When you say left side impact, where is that located? The dealer says there is only 2 sensors on that model?
Paul
Feb 24, 2009 at 1:48 AM
RACEFAN966
  • 5,029 POSTS
Yea there is one on each side of the truck one on the left or drivers side and one on the right the passanger side. As for the splash pan that is that black metal or plastic piece on the front of it that keeps stuff out from the front drive train.
Feb 24, 2009 at 2:49 AM
PCOLUCCI
  • 5 POSTS
Great, I will look to see if I can locate it. I am greatful for the help, this is a great resource for the do-it-yourselfers out there. I've been wrenching for over 35 years so that makes me kind of old school, but I try to keep up. I think I'll invest in an OBD II scanner, it would help, but there's nothing like talking to someone, you can't replace expierience. My next issue will be more challenging, definately a donation answer!!
Paul
Feb 25, 2009 at 3:33 AM
RACEFAN966
  • 5,029 POSTS
Yea I understand as I have been doing this for about 25 yrs now and it just keeps you learning more all the time as the vehicles keep changing. If there is anything more I can do just ask. Thanks again.
Feb 26, 2009 at 2:44 AM
PCOLUCCI
  • 5 POSTS
Because of your help, my air bag system is operating correctly, thanks again. Now as I said earlier here is the problem that I am having with my 98 Chevy Express Van that no one can figure out. It get's terrible gas mileage now. It used to get 14 to 15 on the highway now it gets about 10, and worse when we pull our camper. One day while driving I noticed that the temp gauge was reading about 150deg. after it was warmed up. Knowing that the temp controls the fuel mixture thru the computer I started looking at the thermostat and sensors to get it back in range (which should be 198 or so). I replaced the thermostat with a new 198 that didn,t fix it it would go to temp until the thermo opened up and then fall back down to 150deg. So I changed 1 of the 2 temp sensors. The one on the driver side head (it has a pigtail wire). It didn't seem to fit correctly(the pig tail wasn't long enough, however I installed it any way. Low and behold the temp gauge went up to 225. Wow, to hot, so now I don't know if the engine is actually overheating. I suspected it was the wrong part, which it was, after some investigating I returned it. Put the correct one in, back to 150 deg. There is 1 more temp sensor located on the thermostat housing so I replaced it, still no luck. That is where I am stopped, All sensors are new, new thermo, even a new radiator (had a leak) and still reads 150 after reaching full operating temp. Am I missing something? We don't drive it much because it eats gas. I'll add 2 more things, after I installed the first temp sensor ( the incorrect one) I did drive it for a while and the gas mileage did go back to the 14mpg that we were getting, also at one point I had taken off the thermostat housing for some reason and the ground wire for the temp sensor broke, I replaced it (just the end) with a crimp style connector. I don't know when or why this problem started but nobody that I've talked to can figure it out, and it's killing my wallet. I know this is a long letter but the more info you have the better chance you have of coming up with an answer. Any help would be appreciated.
Mar 11, 2009 at 5:09 AM
RACEFAN966
  • 5,029 POSTS
Ok let see here you have bad mileage and the temp is down. Now are you sure the temp is 150? How did you figure that out? Is that what the guage is saying or has it been checked? If it hasn't been checked then I would have someone with an infered temp guage check the temp. Now we need to know what the temp is at the thermostat housing area and the heads and the lower hose. I also would like to know when was the fuel filter changed last? Get back to me with the needed info and we will go from there. Glad to hear the air bags are working again now lets see if we can get you MPG back.
Mar 12, 2009 at 3:18 AM
CHRISBRYAN2006
My airbag light came on one day and is now stuck on. I tried to have it erased but it pops back on with a code B0100. He seemed to think it was an airbag senser. How do you know which one it is or where it is? Can I buy another and install.
Feb 19, 2019 at 10:42 AM (Merged)
SCOTTY DEE
  • 592 POSTS
The B0100 means there is a problem with the left front end sensor circuit. It could be the wiring to the sensor, an issue at the connector, the sensor itself of the SDM. (sensing diagnostic module).
SPRYGUY
My service airbag light will go on and off at random times while driving down the road. I started looking into it while parked in my driveway and notice that while I'm sitting in the driver seat the light comes on, but if I lift myself off of the seat the light will go off.
SATURNTECH9
  • 30,869 POSTS
Your going to have to have your truck scanned for air bag code's that's your starting point. .Repairing air bag's as a do it your selfer is difficult because you will need a scan tool that can read live air bag and a air bag stimulator in most case's to properly diagnose the problem.
BENNYINC
Cannot reset the air bag cole B0103. Keeps coming back on?
HMAC300
  • 48,601 POSTS
you need to find the source of problem and a pro h as to reset those codes to see what is wrong
DOMERDEL
2003 Chevy Silverado 4X4 V8 4.8 Ext Cab
I'm looking for some initial tips to get started on replacing my airbag clock spring. Bare with me, by initial, I also mean some "obvious" tips on where to get started. I have someone with Chevy expertise, but an Airbag clock spring replacement isn't something he's done before, so I wanted to check with all of you on what I need to do before, during, and after the install.
I had just bought a hanes manual (it's at home, I'm at work). Also, I don't expect anyone to provide me with a 20 page diagram/literature, but more of a summary, and things to check for.
CHEVY22
  • 1,375 POSTS
first let me say , whenever your working on airbags , pull the air bag fuse , i always unplug the battery too just to be sure , i wanted to ask if you have a steering wheel tool , as you will need one ,once the steering wheel comes off your there , no biggie at all
DOMERDEL
I do not have a steering wheel tool. is this something i can rent from Kragen?
CHEVY22
  • 1,375 POSTS
yes you should be able to get one cheap , like 15-20 bucks , you dont need and expensive one , you will probably only use it once , just take your time so you dont break anything and you should be fine
DOMERDEL
i'm making some calls. is it also known as a Steering wheel puller?
COURTNEY1134
i got the truck and the last couple days the service airbag soon light comes on and then after its been off it will go away and it might not come on the whole time i drive it and then out of no where it comes on i assume its the driver airbag because the passenger works when someones in the seat like it should i ve heard tips like plug in and unplug the seat belt and move the seat and all this but when i went to go see if there where any codes the auto parts store said there was none found. i just want to know from someone with some knowledge what this could be caused by... I've also heard possibly the clock spring which if is what kind of price do think were talking just for the part i can do the install my self.
thank you
CHEVY22
  • 1,375 POSTS
yes ,
DENNYP
  • 1,824 POSTS
It should have a history code stored in the computer. It is probably a driver side air bag code related to a wiring connector behind the driver side kick panel. The wire terminals get a poor connection and the connectors have to be replaced.
MQUINN813
Service airbag light on. Found broken wires at two prong male connector under passenger seat. Is there a part number for this connector or do I have to hit the salvage yards?
HMAC300
  • 48,601 POSTS
you can either get it at salvage or dealer only item. however air bag wires are very small so make sure it is connected right and routed so as not to do it again. this should really be done at dealer so as to not have air bags explode and take out windshield along with replacement bags.
RDOGBITE
I had the airbag module repaired and reinstalled it and the light still comes on. What do you think??? We reset the codes with acode reader and it still comes up communication malfunction the code is B0100efsi communication failure
BRIAN 1
  • 1,030 POSTS
b0100 is the l/f impact sensor code,you said you replaced the module,did you replace the SDM based off the b0100?need more info.
BMITCHELL79
I recently replace the seats in my truck and the airbag light is on now. Does this mean that the airbags are not working? What can I do to fix this??
DENNYP
  • 1,824 POSTS
First, you need to have it scanned for trouble codes. Post the codes for me.
EFCDENG
The "Service Airbag" message comes on only when the vehicle sits for several hours in the hot sun with the windows up. Once the temp inside the vehicle decreases the messege goes away. When it is cloudy or the temp is not too hot I can go several weeks without the message.
What would cause the message to appear only under hot weather conditions? I have read that dealers have trouble pinpointing the fix for this problem and start by replacing the crash sensor module under the hood. Any thoughts?
HMAC300
  • 48,601 POSTS
if you live in a northern climate where road salt is used there is a tsb on this. check with a dealer because moisture is getting into module which is under the seat causing a problem with air bag light. they will need your vin and it may be covered and may not. If yo purchased this vehicle new you would have been notified .
