2005 Chevy Silverado 2005 Chevy Silverado Crew CAB A/C
STREETRACER
  • 2005 CHEVROLET SILVERADO
  • V8
  • 55,000 MILES
This weekend I had my car detailed, when I drove it in I had the A/C on but when I drove out the A/C no longer would blow. The lights all work on the instrument panel but when I turn it on nothing happens. The heater has the same issue, I looked at my fuse panel in the engine compartment and none are blown, I also checked my belts and they both are there. So what could it be? Why would it not blow at all? If I change it from cold to hot I can sorta tell the difference in temp but that’s it. Any help would be appreciated.
Monday, October 13th, 2008 AT 4:55 AM
RHALL77
  • 3,361 POSTS
Check and make sure they didnt disconnect or break a electrical connector off.
Monday, October 13th, 2008 AT 12:33 PM
STREETRACER
I have checked the wireing but can not find anything that is not hooked up.
Monday, October 13th, 2008 AT 9:02 PM
RHALL77
  • 3,361 POSTS
Sounds like a possible motor or resistor. Wiggle the wiring first, if that doesnt work, take a hammer and lightly tap the motor and see if it turrns on. A screw driver handle will also work to.
Tuesday, October 14th, 2008 AT 7:13 AM
