HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Chevrolet
Silverado
Climate Control
Air Conditioner
Blows Hot
1995 Chevy Silverado AC
E1015824
MEMBER
1995 CHEVROLET SILVERADO
V8
2WD
AUTOMATIC
119,000 MILES
My ac in my 1995 silverado truck is blowing hot air all the time.
Tuesday, June 22nd, 2010 AT 12:34 PM
MIGHTY_MAX
MEMBER
Get some guages and check the pressure in the system.
While AC is on, low side should be between 40 - 45 psi
High side will be between 200 - 250 psi.
If you just stick guages on w/ AC off, then pressure should be even between both sides.
Maybe 50 - 65 psi both High and low.
Tuesday, June 22nd, 2010 AT 12:49 PM
MIGHTY_MAX
MEMBER
Another quick way to tell is if you turn on the A/C and the clutch doesn't kick in.
Usually means no pressure. So an empty or low system.
On my 91 Chevy, it will cause the A/C display on my panel to blink.
Tuesday, June 22nd, 2010 AT 12:55 PM
Please
login
or
register
to post a reply.
Related Air Conditioner Blows Hot Content
2005 Chevy Silverado Hot Air
My 2005 Silverado K1500hd Has An Ac Issue. The Ac Run Well When I Am Driving On The Interstate Or At Speed. When I Am Stopped Or In Stop...
Asked by
Kingtaupo
2005
CHEVROLET SILVERADO
2005 Chevy Silverado 2005 Chevy Silverado Crew Cab A/...
This Weekend I Had My Car Detailed, When I Drove It In I Had The A/c On But When I Drove Out The A/c No Longer Would Blow. The Lights All...
Asked by
StreetRacer
2005
CHEVROLET SILVERADO
1983 Chevy Silverado Why Does My A/c Kick Off?
When I Take A Turn That Is Just A Little Bit Harder Than Switching Lanes My A/c Makes A "pop" Sound And Then Starts Blowing Hot Air;...
Asked by
marine18
1983
CHEVROLET SILVERADO
1995 Chevy A/c Service
Hello, I Have A 1995 Chevy Pickup With The 4.3 Liter V-6 With Over 225,000. My Compressor Started Making Noise So I Decided To Replace...
Asked by
BD700DOM
1 ANSWER
1995
CHEVROLET SILVERADO
A/c Recharging
A/c Must Have A Leak It Won't Hold A Charge For More Than 2 Days. I Got Some Stop Leak And A Can Of 134a To Try And Charge It Up Again....
Asked by
Harveyfitz
1995
CHEVROLET SILVERADO
VIEW MORE
AC Compressor Replacement Video
Heater Not Working
Air Conditioner - Vacuum Down and Recharge
