2001 Chevy Silverado truck won't start
SILLANO
  • 2001 CHEVROLET SILVERADO
  • V8
  • 127,000 MILES
Hi - my truck stalled out at a stoplight and I haven't been able to start it since. I replaced the fuel filter. No change. It will start imtermittently for about 1-5 seconds but then stalls out. If I press on the gas this usually kills it, or it will increase in RPM to about 2000 but no higher and then die.
Thursday, January 24th, 2008 AT 4:10 PM
MASTERTECHTIM
  • 4,749 POSTS
Sounds like weak fuel pump. You will have to check pressure
Thursday, January 24th, 2008 AT 4:14 PM
SCOOTY62
Check the fuel pressure for sure. Did it throw a code?
Might consider Idle air control valve or throttle psition sensor.
Friday, January 25th, 2008 AT 8:18 PM
Related Engine Not Running Content
