2000 Chevy Silverado V8 Four Wheel Drive Automatic
I have a silverado 6 litre Diesel that had an alison Auto gear box.
Had a second hand motor fitted and since then the gear box when cold changes and kicks down. But when it heats up it stays in top gear untill I stop and change the gear shift to park or reverse and then it just stays in 1st gear. When it is cold again it is O.K. When it is staying in top gear I can stop and it will take off in top gear unless I move the gear shift. There is a gear tempature gague on the dash for the gear box and it seems to be working as when cold it reads cold and after driving for 15 minutes or so it comes to about half way. The only oter thing I have noticed is the oil pressure gague for the motor reads past full at all times when the motor is running.
Your sugestions would be appreciated. NOEL.
Tuesday, October 5th, 2010 AT 5:16 AM
