2000 Chevy Silverado starting
LIL_MAMA
  • 2000 CHEVROLET SILVERADO
2000 Chevy Silverado Two Wheel Drive Manual
the first time I start my truck for the day you can hear the starter go but the truck will start you can hear it try to after awhile but the battery will go dead before it will start. You can get it to start if you spray some starting fluid into the carburetor it will start. But once it has been started once and run for a few minutes it has no problem starting for the rest of the day
we replaced the regular maintence (spark plugs wires ect.), Starter, fuel pump
Monday, December 1st, 2008 AT 11:08 AM
DOCFIXIT
  • 18,828 POSTS
Do you hear fuel pump when key is first turned?
Monday, December 1st, 2008 AT 11:51 AM
LIL_MAMA
Yes I can hear it
when the truck is running it is rough
Monday, December 1st, 2008 AT 1:13 PM
DOCFIXIT
  • 18,828 POSTS
Go to an Auto Zone and have truck scaned for trouble codes then post results.
Monday, December 1st, 2008 AT 1:18 PM
LIL_MAMA
No codes since I replaced bank1 caylitic converter
Monday, December 1st, 2008 AT 1:21 PM
Related Spark Plug Replace/Remove Content
