Engine stalls while going down the road?
JESSICANJK
  • 2000 CHEVROLET SILVERADO
  • 5.3L
  • V8
  • 4WD
  • 160,000 MILES
I had a bunch of codes fixed them then I had an 02 bank 1 sensor 1. Fixed that. Now a multi misfire it runs sluggish will stall out. I have replaced the 02 sensor, plugs wires, had injectors cleaned, changed the fuel pump and filter and sensor. With the fuel pump I changed the throttle body and sensors, some new coil packs and the relay that the coils run to. Basically you name it I have tried. I do not know what else to do!
Thursday, September 10th, 2020 AT 2:38 PM (Merged)
KEN L
  • MASTER CERTIFIED MECHANIC
  • 48,420 POSTS
This sounds like you have a crankshaft angle sensor that is not working right which will not set a code. Here is a guide to help you see what you are in for when doing the job:
Just is case lets run the codes again.
Cheers, Ken
JESSICANJK
I have already replaced that. It still hesitates to start, it had a misfire code first then that went away, then the 02 code then that went away, then no code and now misfire. But I have replaced all the above including the crank sensor and the problem is still there! I do not know what else to try.
KEN L
  • 48,420 POSTS
Okay, lets test the fuel pump which go out all the time in these trucks. Here is a guide to help you test the pressure which should be between 55 and 62 PSI:
Cheers, Ken
JESSICANJK
I replaced the fuel pump. Everything I replaced is in the first post I made.
KEN L
  • 48,420 POSTS
Can I ask if it was a AC Delco pump?
Related Engine Stall While Driving Content
