Hello again! My truck will crank but not start. The battery is fine, it has gas, and the fuses are ok. I do not hear the fuel pump turn on when I try to start the truck. The fuel pressure release valve on the throttle body has no pressure hardly. So I sprayed starter fluid in the air intake and the motor will briefly start then. So my question is besides removing the bed of the truck and checking the voltage at the fuel pump, where can I check it that might be easier? All I have is a meter in the garage, no scan tools. The check engine light is not coming on.
SPONSORED LINKS
Wednesday, March 11th, 2009 AT 2:47 PM
