Vibration started last week from idle to 35 mph and got worse each day. I changed the Carrier Bearing, all three ujoints and rotated tires. Now the vibration is minor up to 35 mph and gets worse up to 48 mph then settles down. Although still there at 50 and above it is not as noticeable. What else can I do to correct this problem and will it damage the truck more if I continue to drive it?
It doesn't vibrate at a certain rpm but by mph.
Apr 25, 2008 at 10:24 AM
