Engine stalling?
BEN124
  • 1999 CHEVROLET SILVERADO
  • V8
  • 4WD
  • 98,568 MILES
I have a 1999 chevy silverado with a 5.3 and during the spring/summer months, when local gas stations switch to summer fuel randomly I will go to start the truck up in the morning before work, and it will studder and stall, but once left running until it gets to operating temperature if you turn it off it will fire back up without a problem any ideas?
Saturday, February 6th, 2010 AT 12:15 AM
  • 109,885 POSTS
Have you checked fuel pump pressure? Has the check engine light ever come on?
This guide can help us
https://www.2carpros.com/articles/engine-stalls
Sunday, February 7th, 2010 AT 6:12 PM
BEN124
No I haven't checked the pressure, and no the check engine light has never come on just confuses me why this only happens in the spring/summer
Sunday, February 7th, 2010 AT 6:16 PM
  • 109,885 POSTS
That is odd. THe reason I asked about the engine light is because I question the temp sensor. It tells the computer the ambient temp and coolant temp. From that, the computer decides how rich or lean to make the fuel mixture. For example, if it is 50 degrees outside and the computer thinks it is -40, the fuel mixture will be too rich for the engine to run properly.
Sunday, February 7th, 2010 AT 6:38 PM
BEN124
Yea I've had the truck to 3 different GM dealers with no results just seem to be "throwing parts" at it in attempt to hopefully by a small chance of luck fix it, but at this point whatever gets the job done. I appreciate your time if you get anymore ideas I'm willing to try it
Sunday, February 7th, 2010 AT 6:43 PM
KOMLOSAN
  • 138,000 MILES
Driving 65 mph, heard a popping sound and when I was giving it gas nothing was happening and I seen my rpms drop to 0 and my power steering stopped working and now I cant get it to start back up, I dont see any fluids leaking anywhere all my electrical is still working also. Could it be the alternator or is this an engine problem?
Thursday, September 3rd, 2020 AT 12:20 PM (Merged)
JDL
  • 16,098 POSTS
I'm not sure about the noise, did you check accessory belt, under the hood. If it cranks good but won't start, have a helper crank it while you visually check for spark at the plugs. If spark everywhere, check fuel pressure. Start with the basics.
KRAMEBL
  • 6 POSTS
  • V8
  • 4WD
  • 163,000 MILES
I parked the vehicle running fine and replaced the steering column to try and eliminate the noise I experienced when turning to the right. After replacing the column and installing my old ignition tumblers for my key, the engine turns over fine tries to run and the second you let of the key the engine dies. Checked fuel pressure 60 lbs. Good spark it seems, and the fuel pump runs and their is good fuel quantity. Checked all the fuses and relays they test good MAP sensor when unpluged has no effect on the situation. Could it be in the BCM.
Thursday, September 3rd, 2020 AT 12:21 PM (Merged)
RHALL77
  • 3,361 POSTS
Is there a security light on? Is you ingnition switch lined up properly? You may have it off a tooth and thats why it shut off when you let off the key?
KRAMEBL
  • 6 POSTS
No security light on and no codes, double checked the lineup of the tumblers it seems to be fine.
RHALL77
  • 3,361 POSTS
Not the tumblers, the ingnition switch it self.
KRAMEBL
  • 6 POSTS
Im sorry thats what I meant the only way I could get the ing switch in or out is to be in only one position if I rotate the slot inside the column the switch will not go back in, it seem to only go in one way.
RHALL77
  • 3,361 POSTS
With it where it is at now, can you remove the key in the lock position.
KRAMEBL
  • 6 POSTS
No the switch will not come out of the column.
KRAMEBL
  • 6 POSTS
Im sorry the key only comes out in the off position no other. Could this be a BCM issue not recognizing the Hall effect sensor in the new steering column?
RHALL77
  • 3,361 POSTS
I think there is a problemin the ingnition switch
KRAMEBL
  • 6 POSTS
Found out the problem the new column has a hall effect switch that the BCM looks at for security purposes and it was not recogonized so it went into the security mode with now display on the dash. I tore the column appart and replaced the new column switch with the old hall effect sensor and it started right up. The only other way to fix the problem was to go to someone that had a tech II programmer and reprogram the BCM, The truck would not run so I would have had a towing bill on top of the programming charge.
Thanks for the support.
MEGAONE
I have a 99 Silverado 5.3 198k miles, and was trying to diagnose a problem where it would run fine when you accel slowly, but the minute you apply any load it would back-fire. 7 people have attempted to find the problem, and failed. I bought a small scanner, and it came up bad crank sensor. I replaced the crank sensor, and now it will turn over, catch, but dies right away. I still get a EGR low voltage on key on, but that has never effected starting to this point. I have replaced the following in trying to get the original problem fixed. New: Fuel pump, TPS, plugs, wires, fuel cap, fuel regulator. Cleaned: EGR, PCV, MAP, MAF. Desperate for help thanks you.
Thursday, September 3rd, 2020 AT 12:22 PM (Merged)
2CARPRO JACK
  • 11,533 POSTS
Install a fuel pressure gauge to be sure it is keeping the pump running. Also need to check for spark, to see what it is losing when it dies and we can go from there
MEGAONE
Fuel guage installed all pressure was normal before installing the crank sensor. That was one of the first suspects, "thinking fualty fuel pump" It was about 53 at key-on, then varied at about 60 at high RPM. WIll check spark next. Thanks for the suggestions.
LOGICZERO21
  • V8
  • 4WD
  • 227,000 MILES
1999 Silverado 5.3 V8
The other day on my way to work, my truck died. I stopped, and restarted it, and it kept going for two more blocks before dying at an intersection. It will crank strongly, and sometimes it'll start but it won't stay running. It sounds like it's either starving for air or starving for gas. The fuel filter was old so I replaced it, I've Triple Checked the fuses under the hood and inside the cab. The Fuel pressure regulator seems to be okay, and the fuel pump IS engaging. We've checked the plugs, fuses, Fuel pump, regulator, and filter. When it DOES turn over, it'll run fine for a few seconds, untill it starts to sputter and die. Sometimes right when it's about to die, it'll rev back up to normal idle. Completely Dumbfounded. I did remove the new filter today to see if the gas is the filter is discolored, and it's as normal as can be. Any help would be greatly appreciated.
