Engine Performance problem
1998 Chevy Silverado V8 Four Wheel Drive Automatic
engine cranks over but will not fire, changed plugs, fuel filter and fuel pump still getting nothing
Monday, September 1st, 2008 AT 5:29 PM
MECHANIC
What are you missing spark or fuel?
SPONSORED LINKS
Wednesday, September 2nd, 2020 AT 5:41 PM
MASTERWILLIAM1206
MEMBER
Getting spark and fuel is reaching engine
MECHANIC
Listen to the injector/s are they pulsing
MECHANIC
Get a carb cleaner and spray into the carb or the throttle body on an EFI. Did it start and die? If not disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel problem, check the fuel pressure to rule out the fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil, distributor pick-up coil, ignition control module, cam and crank sensors-
