1998 Chevy Silverado cutting out
MIKE15
  • 1998 CHEVROLET SILVERADO
  • V8
  • 4WD
  • 187,000 MILES
I've replaced the spark plugs, spark plug wires, disteribauter cap and rotor, my truck will start but then dies like you turned the ignition off. Then ill be driving down the road and it will start cutting out, the rpm gauge drops and the vehicle feels like its chugging, fuel pump works fine, then ill pull up to a stop light and it dies again so I start it and its fine but then does it again. Just looking for some thoughts on what it could be thanks
Saturday, September 25th, 2010 AT 11:36 PM
  • 109,885 POSTS
Have you actually checked fuel pump pressure? Also, has the check engine light ever come on?
Sunday, September 26th, 2010 AT 12:21 AM
MIKE15
  • 5 POSTS
No I havent checked the fuel pump pressure, and the check engine light is on
Sunday, September 26th, 2010 AT 8:17 AM
  • 109,885 POSTS
Start with the check engine light. Have the computer scanned to see what trouble codes are stored. Most parts stores will do it for free.
Have that done and let me know what you find.
Monday, September 27th, 2010 AT 7:27 AM
MIKE15
  • 5 POSTS
Had that done had to replace egr, throttle posotioning sensor, mafs, and gas cap, fuel pressure is good, still giving me problems mafs reading is erratic now according to a scanner. Could it be I got a bad one or wiring harness?
Monday, September 27th, 2010 AT 6:39 PM
  • 109,885 POSTS
It could be either one, wiring or part. Since the part is most likey still under warranty, I would try to replace that first before tracking a wiring issue.
Tuesday, September 28th, 2010 AT 7:33 AM
MIKE15
  • 5 POSTS
I replaced the mfas so it must be a wiring issue, would it be the harness that plugs into the mfas
Tuesday, September 28th, 2010 AT 5:50 PM
MIKE15
  • 5 POSTS
Could it possibly be the ecm or computer, or the camshaft position sensor thats where the wires go to
Wednesday, September 29th, 2010 AT 8:21 AM
  • 109,885 POSTS
Something tells me that it deals with the wiring. The PCM could be bad, but I doubt that is the problem.
Friday, October 1st, 2010 AT 9:48 AM
Related Spark Plug Replace/Remove Content
