1998 Chevy Silverado
ROWDYPIPER
  • 1998 CHEVROLET SILVERADO
  • V8
  • 4WD
  • 216,000 MILES
The engine turns over, but it sounds like timing is off. It turns rough and wont start.
Sunday, February 7th, 2010 AT 9:17 PM
  • 109,747 POSTS
Have you checked timing? Is the check engine light on? When was the last tune up? Have you checked for vacuum leaks? Fuel pressure?
Wednesday, September 2nd, 2020 AT 5:35 PM
ROWDYPIPER
I have checked the crankshaft positioning sensor and the camshaft positioning sensor, both have voltage readings but they seam to be unstable. I have not checked timing or for vacuum leaks beacuse it won't start. I don't know if the check engine light is staying on because the engine wont start. I have not checked fuel pressure but I know the fuel pump is coming on and it sure does not seem like a fuel problem.
