1997 Chevy Silverado Turns over, wont start.
TIM KNUTSEN
  • 1997 CHEVROLET SILVERADO
  • V8
  • 4WD
  • 20,800 MILES
Engine died while driving. Won't start. It blows ECM-B Fuse when key is turned to on position. I cant read diagnostics code with my super-chips programer because it tells me my ignition key is not turned on. The engine will turn over, but it will not start. The fact that I cant read the code really pisses me off. Please help, I need the truck for work, and I cant afford to take it to a shop. I will use this site again and gladly make a donation if I can get to work and make some money.
Wednesday, July 7th, 2010 AT 3:45 PM
When the ECM B fuse blows there's no power to the fuel pump try this pull the fuel pump relay and see if the fuse blows
Wednesday, July 7th, 2010 AT 3:53 PM
TIM KNUTSEN
  • 6 POSTS
This worked. Should I replace relay?
Wednesday, July 7th, 2010 AT 4:20 PM
TIM KNUTSEN
  • 6 POSTS
Pulling the fuel pump relay keeps the fuse from blowing. I replaced the relay with a new one, but the fuse still blows. Is the fuel pump the problem? Bad Ground?
Wednesday, July 7th, 2010 AT 5:42 PM
Unplug the fuel pump connector check again if the fuse will blow-don't blow-replace the fuel pump-Bad ground will not cause your problem here unless its shorted to the fuel pump hot circuit gray wire
Thursday, July 8th, 2010 AT 1:43 AM
TIM KNUTSEN
  • 6 POSTS
I pulled the pump plug and it did not blow the fuse, but I have no power to the gray wire
Thursday, July 8th, 2010 AT 1:21 PM
After 2 secs the fuel pump will lose power when the fuel pump de-energizes. If no power at the gray wire check this wire with the black and white wire if its shorted together
Thursday, July 8th, 2010 AT 1:54 PM
TIM KNUTSEN
  • 6 POSTS
How do I do that?
Thursday, July 8th, 2010 AT 6:58 PM
By using a multimeter check the 2 wires together while doing a continuity test if there's continuity exist its shorted together wires are touching together and its not suppose to.
Whle fuel pump connector disconnected -I want you to power the gray wire on the fuel pump side from the battery did the fuel pump come on and it started up
Thursday, July 8th, 2010 AT 7:53 PM
TIM KNUTSEN
  • 6 POSTS
Your last message needs to be very clear, step by step because I don't know electrical technical terms such as continuity but I will look it up. You said "with the fuel pump connector disconnected, supply power from the battery to the gray wire to see if the pump comes on. If its disconnected, how will it come on? Did u mean power from battery straight to the pump harness gray wire, not through entire harness? That makes sense, sorry.
Sunday, July 11th, 2010 AT 1:28 PM
Correct, You're right on the money
Sunday, July 11th, 2010 AT 2:19 PM
TIM KNUTSEN
  • 6 POSTS
What about the ground?
Sunday, July 11th, 2010 AT 10:33 PM
The ground is the black and white wire on the fuel pump connector-
Monday, July 12th, 2010 AT 12:49 AM
