Welcome to the forum, my info shows you have that spider fuel system, it is noted for problems, sometimes the fuel poppets stick. I wouldn't suspect the pump without using a fuel pressure gage on it. Even then, I'd check for good voltage and ground at the pump. Key on voltage at the pump and engine running voltage at the pump are two different things. I'd check fuel pressure key on, no crank, and engine running.
SPONSORED LINKS
Wednesday, September 2nd, 2020 AT 5:55 PM
