backfired and now it won't start?
15,290 MILES • 6 CYL • 2WD • AUTOMATIC
FORDREBEL87
my brother has a 97 chevy silverado 1500 4.3 vortec motor it was running then all of a sudden it backfired and now it won't start what do you think is the problem i cut the cat out and it still won't start
Aug 3, 2010 at 4:46 PM
SQM
  • 6,383 POSTS
An engine backfires due to having unburnt fuel being ignited inside the intake and creates the loud bang.
This explosion can bend the throttle actuator plate, push intake gaskets outward creating a vacuum leak and even blown apart a plastic intake manifold. When intake manifolds were made of aluminum they could better withstand this kind of problem.
This is a helpful article on backfires. This will help you guide thru what to look for.
https://www.2carpros.com/articles/engine-backfires-while-running
If the backfire is severe enough it will blow out gaskets and which will prevent the engine from starting.
Aug 8, 2021 at 5:10 AM
