1994 Chevy Silverado
LARRYCATFISH
  • 1994 CHEVROLET SILVERADO
Transmission problem
1994 Chevy Silverado V8 Four Wheel Drive Automatic
I can try to lock my 4wheel drive in and fills like it goes in but the light don't come on in the floor and the front wheels don't spin when I get in the mud I have checked the all the wires and all look good please help
Sunday, September 12th, 2010 AT 3:18 AM
  • 109,885 POSTS
Do you have an electric shift or on the floor 4wd shifter?
Saturday, September 18th, 2010 AT 11:51 PM
DWB812
  • 108 POSTS
It is likely that your interlock in the front differential has failed. If it's the factory original, it's a heat operated device that takes a few seconds to engage (at least) when you throw the lever into 4WD. I recommend one of the "instant on" replacement interlocks that have no delay. Installation is pretty easy except for tight access. Cut wire ties to free wires and electrical connector, unbolt old one, unplug and remove; bolt in new one, plug in and tie wrap up wires neatly so they don't catch any snarly stuff on the trail and you should be back in business. Good luck and I hope this helps.
Sunday, September 19th, 2010 AT 7:53 PM
LARRYCATFISH
Shifter on the floor
Monday, September 20th, 2010 AT 7:52 PM
  • 109,885 POSTS
Either there is a linkage problem to the transfer case, or the interlock, as mentioned, isn't engaging the front axle.
Tuesday, September 21st, 2010 AT 1:08 AM
