1994 Chevy Silverado Speedometer Fluctuates
TABERSKIT
mileage: 202000
Transmission: automatic with overdrive.
engine size: 305 V8
I have been experiencing some odd things lately with the tranny. I drive on the thruway / freeway alot, and @ approx. 65 miles mph, the speedo needle starts to ping from 65 mph to 80 mph and back again.
It seems to just go crazy. During this action, the truck feels like it is going to "Die", and then picks back up to speed and continues. Sometimes this happens once to three times per day. Any answers !
Aug 27, 2007 at 8:02 AM
SERVICE WRITER
  • 9,123 POSTS
There should be a plug on the transmission drain pan.
Remove it, drain the fluid, replace the plug gasket, install the plug. Through the dipstick hole add a quart and check the fluid, add more as needed until level is good. Should be less than 3 quarts needed. You should use honda fluid.
Jun 8, 2007 at 1:15 PM
MERLIN2021
  • 17,250 POSTS
May be the VSS Vehicle speed sensor on most c1500 tranny's it's on the left side of the tranny. it has a 2 wire connector.
LTGREEN/BLK
Purp/WHT
there is also a vss buffer in the right side of the dash!
Aug 27, 2007 at 8:31 AM
Suggested Repair
Inspect the vehicle speed sensor on the left side of the transmission (two-wire connector) and the VSS buffer on the right side of the dash. One reply also suggested draining and refilling transmission fluid, but that advice conflicts with the speedometer symptom and should not be treated as the primary fix.
Conversation Summary
The owner of a 1994 Chevrolet Silverado with a 305 V8 and automatic overdrive reports that around 65 mph the speedometer jumps between about 65 and 80 mph while the truck briefly feels like it is dying, then recovers. This can happen one to three times a day. One reply suggested draining and topping off transmission fluid. Another pointed to the transmission vehicle speed sensor and the dash VSS buffer.
