Engine cranks but does not start
MICKKING
  • 1993 CHEVROLET SILVERADO
  • V8
  • 190,000 MILES
It turns over fine and runs like a champ but getting it to start is the trick. I thought it was the fuel pump and/or fuel filter so both replaced twice! But nothing helped. I reprime multiple times and can even smell gas at times if primed enough but it just keeps turning over but never will crank like its not getting gas or something. But if it was the fuel injector it wouldn't run right when driving so I know its not that. If its the lines I would smell it or still notice it when driving. The thing is though at times it will crank on the first prime but has to turn over a bit but then others it takes ten minutes to get it to crank. I need this fixed before my starter goes out or worse.
Tuesday, August 12th, 2008 AT 2:58 AM
This is most likely either a fuel issue or an ignition issue. So that means we need to start with just checking the pressure and going from there.
If we have pressure, then we need to check to see if the injectors are firing.
https://www.2carpros.com/articles/how-to-test-a-fuel-injector
If they are then we need to pull a plug and make sure they are not fouled.
Replace the plugs at that point and then hold them against the block and crank the engine to find out if you have spark.
Then we can take the next steps depending on what we find.
Thanks
Thursday, January 13th, 2022 AT 5:46 PM
Related Engine Not Running Content
