1993 Chevy Silverado starting problem after warm up
MIKEPER66
  • 1993 CHEVROLET SILVERADO
  • V8
  • 4WD
  • 255,000 MILES
My truck is a 1993 Chevy K2500 with a 6.5L diesel turbo. My problem is after the engine has warmed up and I turn it off it doesn't want to start again. It only does this after sitting for 10- 15 min. When it is cold I turn the key let the glow plugs cycle and it starts right away. After it warms up I turn the key to let the glow plugs cycle and the glow plug light doesn't come on. I have changed the control module twice and the glow plugs at my mechanics request. The truck runs very good once it has started. Please help thank you
Wednesday, April 2nd, 2008 AT 5:36 PM
MPCJAX
I have the same issue with a K3500 dually but believe that I have the part coming in to fix the issue. The switch in the thermostat water neck crossover pipe is bad (terminals broken off). Once I change it I will let you know what the results are.
Mike
Wednesday, September 2nd, 2020 AT 6:40 PM
MIKEPER66
Hey mike I was wondering how you made out?
