1993 Chevy Silverado Fuel system
PHILNAMBER
  • 1993 CHEVROLET SILVERADO
Electrical problem
1993 Chevy Silverado V8 Two Wheel Drive Automatic A lot miles
I have replaced fuel pump and fuel filters because I thought that was the problem. Now the same problem is back the truck will run for a minute and just stop if it set's for a minute it will start againe sum times but now it won't start at all it turns over but will not start.
Sunday, March 22nd, 2009 AT 8:43 AM
JDL
  • 16,098 POSTS
Hello, did you ever check fuel pressure? If you have TBI, do the injectors spray gas, that doesn't mean you have good pressure, but, it shows the injector/s are pulsing. If you do a lot of cranking and the injectors are pulsing, you may flood it.
Any codes, do you have spark at the plugs?
Wednesday, September 2nd, 2020 AT 6:41 PM
SFBDBURBAN
  • 5 POSTS
The thing that I don't like about these forums is that the original person with the problem never responds AFTER they have their problem fixed. So I'm sitting here at 3 in the morning reading about TBI injectors not firing hoping to find an answer but just more dead ends.
Earlier you were asked if you check the fuel pressure -You need to check the fuel pressure EFI system don't like low fuel pressure also check the injector/s solenoid resistances if okay could be very well be an ignition system problem.
