Does the engine have 300000 miles on it? If so, check the spark plugs, ignition wires, distributer cap and rotor first. Check for vaccume leaks and a sticking PCV valve. Â If they are ok, it sounds like the throttle position sensor (TPS) and/or the ignition module is going bad. Considering the mileage I would just change the TPS -- as for the ignition module -- have that tested. Autozone or a place like that will test it for free. They may even test the TPS too. If you want to test the TPS sensor yourself let me know.
  Â
Tuesday, May 20th, 2008 AT 5:20 AM
