1990 Chevy Silverado Won't Start
BOYD79
  • 1990 CHEVROLET SILVERADO
  • 8 CYL
  • 150,000 MILES
Engine cranks but won't start. Changed spark plug wire, spark plugs, ignition coil, distributor cap, rotor, high voltage coil lead, distributor body, ignition signal sensor and ignition module tested fine. What else could it be?
Thank you, Randy
Saturday, February 6th, 2010 AT 6:29 PM
You did the ignition system but did you check the fuel pressure to rule out the fuel system-could be no fuel causing it not to start
Thursday, September 3rd, 2020 AT 9:53 AM
BOYD79
It started! Turned out to be a bad pick up coil.
