I have an 88 chevy pickup truck with high miles and from time to time the speedometer stops working. I used a code scanner and it said speed sensor was bad, but where is it located. Also when the speedometer doesnt work I seem to have more power going up hills or on interstate.
SPONSORED LINKS
Thursday, September 23rd, 2010 AT 8:04 PM
MECHANIC
The power issue is odd unless the trans isn't shifting into a higher gear. That will cause it to seem like it has more power.
As far as the VSS, I need to know what trans you have.
Thursday, September 23rd, 2010 AT 9:36 PM
DBCOOPER1961
MEMBER
My 1988 chevy silverado has a 700r4 transmission with overdrive.
SPONSORED LINKS
Thursday, September 23rd, 2010 AT 10:20 PM
MECHANIC
With the 4wd set up and the 700R4 trans the VSS is located on the transfer case.
