white smoke
GIVENS86
I have a 2000 Chevy S-10 automatic with 151059 miles and it died three times this morning on my way to work and my oil gauge was low. So, I put in oil and on my way home white smoke started to come out the muffler and the truck felt like it did not want to shift. I was able to go about 30 mph without the smoke for about 15 miles, then I was able to go 60 for another 15 miles until I was going about 55 and it felt like it wanted to die before it caught itself. Did I put too much oil in it, my temp gauge was normal as was everything else.
Nov 20, 2007 at 11:03 AM
  • 75,988 POSTS
White smoke is an indication that coolant is being burn in the combustion chamber. Get the tests done below to find out what's happening.
Have it block and pressure tested-do the block first to pinpoint a combustion leaking into the cooling system or a gas analyzer to sniff for hydrocarbons at the radiator fill neck.
Pressure test: do not do a pressure test if there's leakage at the headgasket this might cause coolant into the cylinders and lock it up or bend a connecting rod if cranked thereafter. The headgasket should be repaired before doing the pressure test.
If the block and pressure test passes check the following: Thermostat,Pressure test the Rad. cap,Clogged radiator,Fan clutch,Radiator electrical fan,collaspe hoses,water pump.
Nov 21, 2007 at 4:50 AM
