possible head gasket
BOBJR
i have a 1994 s10 4dr blazer.4.3 vortec ''w'' not sure how many miles on it.it has been blowing thick white smoke out of exhaust.just changed the cpi.i was told it was a head gasket and i have been told it was an intake gasket.which could it be,and what signs should i look for to tell if it was a gasket?
Nov 9, 2007 at 11:18 AM
  • 75,988 POSTS
To confirm the headgasket do below
Have it block and pressure tested-do the block first to pinpoint a combustion leaking into the cooling system or a gas analyzer to sniff for hydrocarbons at the radiator fill neck.
Pressure test: do not do a pressure test if there's leakage at the headgasket this might cause coolant into the cylinders and lock it up or bend a connecting rod if cranked thereafter. The headgasket should be repaired before doing the pressure test.
Nov 9, 2007 at 11:36 AM
