I have several people that think it may be the problem. How do i remove ignition?
1989 Chevrolet S-10 Battery Drain
I have several people that think it may be the problem. How do i remove ignition?[/quote:21059837c2]
What you just did was disconnect the source of the short circuit-
Case Drainage:
Do this with the voltmeter put neg. lead to neg. terminal of battery. Now probe the top of the battery with the positive lead any readings other than .002 you have a case drainage. clean up with baking soda and water
Parasitic Drain 30milliamps down and better.
You need to follow Mr. SW advise-Hence in the event you remove all the fuses and drainage is still there-disconnect the alternator if that kills the drain you have found your bad friend in the alternator called Diodes- If not keep going we're watching you
You sure the battery is not sulfated. To check do the 3-minute test, apply a 35amp charge to the battery within 3-minutes if battery voltage goes beyond 15.5 volts bingo the battery is sulfated.
Good Luck
Suggested Repair
Reconnect the fuse-box feed and measure parasitic draw, removing one fuse at a time until the draw is about 30 milliamps to identify the circuit. If the drain remains with all fuses removed, disconnect the alternator and check for bad diodes. Also test the battery for sulfation with a 3-minute 35-amp charge; voltage above 15.5 volts indicates a sulfated battery.
Conversation Summary
The owner of a 1989 Chevrolet S-10 reports a slow battery drain that stops when the main feed to the firewall fuse box is disconnected, and asks whether the column ignition switch is the cause and how to remove it. Experts recommend isolating the circuit by checking draw while removing fuses one at a time, aiming for about 30 milliamps. If the drain continues with the fuses removed, they advise checking the alternator diodes and testing the battery for sulfation.
