1998 Chevrolet S-10 Clutch Fluid Leak
INDYGUY32
hello this is my first post... : )
I have a 98 chevy s-10 pickup with a 5 speed and 2.2L
when its summer time my clutch is fine i have added clutch fluid maybe 4 times all summer but as soon as it gets to about 40 deg outside i have to add fluid every day.....does this sound like a bad O ring on my slave cylinder.....clutch still works great just leaks
any help would be greatly appreciated.
Sep 11, 2007 at 12:39 PM
  • 31,937 POSTS
Hi there,
If you are adding fluid that often you do have a leak, peel back the rubber boot on the slave cyl and if there is fluid present the cyl should be replaced, to check the master cyl is a bit harder, look up under the dash where the pedal rod is and have a good look for signs of fluid leaking out of the master cyl.
good luck,
Mark (mhpautos)
Sep 11, 2007 at 5:05 PM
Suggested Repair
Frequent clutch fluid loss indicates a leak. Peel back the slave cylinder rubber boot and replace the slave cylinder if fluid is present. Also inspect the master cylinder under the dash at the pedal rod for leaking fluid.
Conversation Summary
The owner of a 1998 Chevrolet S-10 with a 5-speed and 2.2L says clutch fluid must be added often, especially around 40 degrees, although the clutch still works. The expert says this frequent loss means a leak and recommends checking the slave cylinder boot for fluid and replacing the cylinder if wet, plus inspecting the master cylinder under the dash for leaks.
