she'll crank but wont start
EBM
  • 7 POSTS
I have a 1996 4.3L S-10 and i started having problems with my struck and it wouldn't start so i changed the fuel pump relay and oil pressure sending unit and that did nothing, so i put a new fuel pump in and it still wont start. When i try to start it, it cranks but it wont start and the fuel pump doesn't come on, but the relays click. any ideas?
Oct 18, 2007 at 7:07 AM
2CARPRO JACK
  • 11,533 POSTS
Check for power at the tank unit with key on.Might have a bad connection or might have forgotten to plug in the pump
Oct 18, 2007 at 7:13 AM
EBM
  • 7 POSTS
i checked and it has power, but the pump still isn't coming on.
Oct 18, 2007 at 7:38 AM
2CARPRO JACK
  • 11,533 POSTS
Oct 18, 2007 at 8:07 AM
EBM
  • 7 POSTS
nope, it's all plugged in, unless i missed something and it plugs in on the inside of the tank somehow.
Oct 18, 2007 at 8:18 AM
2CARPRO JACK
  • 11,533 POSTS
Yep, the power has to reach th epump somehow......... there is a harness inside the tank that connects the pump through the tank unit, 2 wire connector on the pump and another 4 wire on the bottom of the tank unit
Oct 18, 2007 at 8:20 AM
EBM
  • 7 POSTS
ok, everything is plugged in and i rechecked the end. 1 is getting constant power to the fuel gauge 1 is on for 3 seconds(relay) going to the pump and 2 are dead(1 going to each pump and gauge). does this mean that i'm only getting power to the fuel pump for those 3 seconds? and if so why is the pump not even coming on for those 3 seconds?
Oct 20, 2007 at 6:58 AM
2CARPRO JACK
  • 11,533 POSTS
Here we go... If you are getting power to the tank and the pump isnt coming on, you will have to drop the tank back out to see why
Oct 21, 2007 at 12:58 AM
EBM
  • 7 POSTS
i have a S-10 pickup so we have the bed raised.
Oct 21, 2007 at 8:10 AM
