2002 Chevrolet S-10 Parking Brake Pedal Fix
JOHNS
My 2002 4X2 Extended Cab's parking brake pedal won't stay down & engage the brakes. Cables are all loose & work fine. How do I go about pulling out the Parking Brake mechanism inside the cab to repair/replace it??
Aug 19, 2007 at 3:54 AM
SERVICE WRITER
  • 9,123 POSTS
I'm not sure on the replacement but We have had good success at getting some penetrating fluid into the mechanism and working the dog the holds it in place.
Aug 19, 2007 at 4:13 AM
JOHNS
[quote:437bc05f1c="johns"]My 2002 4X2 Extended Cab's parking brake pedal won't stay down & engage the brakes. Cables are all loose & work fine. How do I go about pulling out the Parking Brake mechanism inside the cab to repair/replace it??[/quote:437bc05f1c]
Thanks, Paul .... I'll give it a try!!!
Aug 19, 2007 at 7:59 AM
Suggested Repair
Apply penetrating fluid to the parking brake pedal mechanism and work the pawl that holds the pedal down.
Conversation Summary
The owner of a 2002 Chevrolet S-10 said the parking brake pedal will not stay down and engage, while the cables are loose and work fine. They asked how to remove the in-cab mechanism for repair or replacement. The expert was unsure about replacement but recommended applying penetrating fluid and working the pawl that holds the pedal. The owner said they would try that.
