1998 Chevy S-10 Fuel Pressure Light
HIWNGR53
I recently put a 4link suspension in my 98 S10 and had to remove the fuel tank for additional room. I installed a fuel cell in it's place. Now the check engine light stays on. I had the codes checked and it says low/high fuel pressure. All the lines are hooked up just like the stock tank. Is the pressure sensor in the tank or elsewhere. The truck runs perfect but I can't get the truck inspected with the light on. Help!!!
Oct 31, 2007 at 9:38 AM
MERLIN2021
  • 17,250 POSTS
It's on top of the fuel tank..
Oct 31, 2007 at 10:11 AM
Suggested Repair
The fuel pressure sensor is on top of the fuel tank. After replacing the stock tank with a fuel cell, confirm the sensor was transferred and is connected, and verify fuel pressure is within specification so the check-engine light can be cleared for inspection.
Conversation Summary
The owner of a 1998 Chevrolet S-10 installed a fuel cell after removing the stock tank for a 4-link suspension and now has a check-engine light for low/high fuel pressure, though the truck runs well. The expert stated the fuel pressure sensor is on top of the fuel tank.
