1988 Chevrolet S-10 Fuel Starvation
fuel pump may be working but it has to provied the fuel injectors with pressure and volume
if one missing u have no start
check the fuel pressure you may need that pump!
by u putting gas in the TBI and engine starting we know u have spark and the problem is fuel
check the injectors if the are working
and TPS
good luck
let us know
Suggested Repair
Check fuel pressure and volume, then inspect the short rubber hose between the in-tank pump and the sender pipe. A split hose can cause pressure surges and fuel starvation; replace that hose and, if already removed, the pump and strainer.
Conversation Summary
A 1988 Chevrolet S-10 stalled after being refueled and would not restart. The owner confirmed the pump moved fuel and that adding gas to the TBI produced a brief, poor start, pointing to a fuel-delivery problem. Experts advised checking fuel pressure, injector operation, the TPS, and the oil sending unit that powers the pump after startup. The owner found a split two-inch rubber hose between the pump and pipe, which explained the surging pressure, and replaced the hose along with the pump and strainer, solving the problem.
