I ran my tank real low on gas the other day and barely made it to the gas station shortly after that my truck was not starting very easy and was spuddering at higher rpms thought I might have got some bad gas went and filled up the rest of my tank with quality gas still no difference changed the air filter and the fuel filter that was by the power steering pump only filter that I could find still no difference in performance or start up what else should I look for
SPONSORED LINKS
Wednesday, May 21st, 2008 AT 1:26 AM
MECHANIC
4.3L engine the fuel filter on a 1991 S10 is on the inside of the frame on the drviers side.
2.8L engine is behind the power steering pump.
Wednesday, May 21st, 2008 AT 3:19 AM
OBXAUTOMEDIC
MECHANIC
How dirty was the old fuel filter? If you were pulling the very bottom of the tank it is possible some of the garbage on the bottom of the tank may have gotten through the filter to the injectors. Try a good fuel cleaning additive. I would suggest either SeaFoam if available in your area or Lucas. Both clean the whole system. They are the only 2 additives I use.
