s-10 zr2 fuel pump
2010 CHEVROLET S-10
JERRY LEE
I have a s-10 zr2 the veh pump is working and the motor will start, in the past the veh started very quickly, in the past week the motor will turn over several times before it will start, i can hear the fuel pump working, if i let the fuel pump run a few sec. before i turn over the motor to start it will start faster, but not as good as before, is their some kind of check valve bad in the fuel pump and can a person just replace the pump not the hole sending unit.
Nov 21, 2007 at 12:02 PM
  • CAR REPAIR CONTRIBUTOR
The only way to find out is perform a fuel pressure check this will give you a basic idea is to what's going on within the fuel system. Could be pressure regulator/leaking fuel pump check valve/fuel filter/sock .
Nov 21, 2007 at 12:46 PM
