1993 Chevrolet S-10 No Spark at Plugs
BERGUM
i have a 93 s-10 4x4 (143,000mi) with a 4.3 (z VIN)with an automatic tranny.it has a slight knock during acceleration and feels like it's missing.if i keep it in park and keep the RPM's up there is no noise only in forward gears.i found a plug that had broke and replaced it but no fix,since then i changed the 02 sensor, knock sensor and fuel filter.i had a guy check for spark at the distributor cap and i think it was #3 & 5 did not have spark at the cap.he then did a compression check on the number 3 cylinder and said it was only at 50 pounds.will no spark affect the compression of a cylinder since the coil is unhooked for a compresion test.at my whitts end trying to figure out why my truck isnt running right.any help would be greatfull.
May 18, 2007 at 12:43 PM
SERVICE WRITER
  • 9,123 POSTS
since the gauge is where the plug would go, the cylinder wouldn't have spark anyways. You obviously need to resolve the spark issue if you havn't already. I would try cleaning the intake valves to see if that helps the compression. There may be a carbon build up, preventing the seal.
One product I like is seafoam, although GM top engine cleaner is also good as is castle products.
May 18, 2007 at 1:30 PM
MATTHEW999
4.3l fuel pressure. 60psi good spark at end of coil wire but no fire at plugs, installed new dist.cap and rotor button
Jul 13, 2020 at 6:14 AM (Merged)
what about the coil wire to the distributor??
MATTHEW999
strong fire at end of coil wire,none at end of plug wires
re check your cap and rotor. something wrong in there
Suggested Repair
Recheck the distributor cap, rotor, and coil-to-distributor path, since spark at the coil wire is not reaching the plug wires. No spark does not lower a compression reading; if compression stays low, clean the intake valves to remove carbon that may prevent sealing.
Conversation Summary
The owner of a 1993 Chevrolet S-10 4.3 reported a knock under acceleration, a miss, no spark at cylinders 3 and 5, and about 50 psi compression on cylinder 3. An expert explained that disconnecting the coil for a compression test does not affect the reading, advised resolving the spark problem, and suggested cleaning the intake valves for carbon buildup. After a new cap and rotor, the owner still had strong spark at the coil wire but none at the plug wires, and the expert said to recheck the cap and rotor.
