2002 Chevy S-10 Rubbing Over 15 MPH
RICEELISE79
I have a 2002 Chevy S-10 and I have about 150,000 miles on it. Several weeks ago I started to notice a rubbing sound which also resulted in a vibration when I reached about 15-20 mph. I have looked under and haven't seen any noticeable wear on the tire. What could be causing it?
Oct 22, 2007 at 2:25 AM
SERVICE WRITER
  • 9,123 POSTS
Get a look at the driveshaft u-joints. The needle bearings may be in rough shape. Sometimes you can find play in them, and smetimes you need to pull the shaft out to find them overly tight.
Oct 23, 2007 at 10:23 PM
Suggested Repair
Inspect the driveshaft U-joints for rough needle bearings. Check for play; if none is obvious, remove the shaft to see whether the joints are overly tight.
Conversation Summary
The owner of a 2002 Chevy S-10 with about 150,000 miles reports a rubbing sound and vibration starting around 15-20 mph, with no visible tire wear. The expert recommends inspecting the driveshaft U-joints, which may have worn needle bearings, play, or be overly tight and require shaft removal to diagnose.
