2002 Chevy S-10 Cold Start Tapping
SPIDER92691
Have a 2002 Chevy S10 V-6 auto with 58K miles on it. After my last oil change, when cold-start a tapping sound (lifter?) occurs for a couple minutes, then goes away???
Does this sound like an oil pump problem or the wrong oil viscosity was used???
Aug 17, 2007 at 7:23 AM
MERLIN2021
  • 17,250 POSTS
Only one way to tell, perform a pressure test.
Aug 17, 2007 at 7:33 AM
MIKE H R
  • 3,094 POSTS
The lifters could be a little gummed up. it sounds like the lifters are not holding pressure, this is nothing to be allarmed about as long as the tapping stops after a short time and there are no other knocking sounds. When the engine starts it pumps the lifter back up , then the tapping stops. I have a subaru with 137,000 miles on it. I installed a manual pressure guage. When i start the subaru it sounds like a bunch of marbles in it, after running about 5 minutes the sound gets less and less until it stops. I am running 70 pounds of oil pressure. You can add a can of lucas oil or something like stp to keep the engine lubed when you shut it off, so you don't have a dry start. {when all the oil has drained back into the pan} If they get too loud I would have the lifters checked and adjusted.
Aug 17, 2007 at 7:40 AM
Suggested Repair
Perform an oil-pressure test to confirm pump and pressure. Brief cold-start tapping that stops after a few minutes can be lifters draining down; verify the correct oil viscosity, consider an additive such as Lucas or STP to reduce dry starts, and have the lifters checked and adjusted if the noise becomes louder or other knocking appears.
Conversation Summary
A 2002 Chevy S-10 with 58,000 miles developed a tapping noise for a couple of minutes after cold starts following an oil change, then the noise stopped. The owner asked whether this indicated an oil-pump problem or the wrong oil viscosity. One reply said a pressure test is the only way to tell. Another said gummed or draining lifters can cause this and it is not alarming if the tapping stops quickly with no other knocking; an additive may help keep oil in the engine after shutdown, and louder noise should prompt a lifter check and adjustment.
